Return value of Aimeos\MShop\Order\Item\Standard::getRelatedId() must be of the type string, null returned
rvhelp
Post by rvhelp » 21 Oct 2022, 08:38
After updating to Aimeos 22, the following error occurs on the Aimeos backend page for orders:
Re: Return value of Aimeos\MShop\Order\Item\Standard::getRelatedId() must be of the type string, null returned
Post by aimeos » 21 Oct 2022, 08:48
To which version did you update? 22.10.1?
Did you run the migrations? The relatedid column in the mshop_order table seems to be still "DEFAULT NULL" instead of "DEFAULT ''" and the column contains NULL values.
rvhelp
Post by rvhelp » 21 Oct 2022, 09:49
The table Structure was ok, i replaced NULL values with "" and its working now. I have aimeos 22.7 atm.
Thank you for the Help!
