Product csv import: product.url
heural
Post by heural » 09 Nov 2022, 10:20
Hi Aimeos-Team!
We import products from our external product-management with a custom csv-import (added a decorator class to adapt the data). So far so good.
We have products they have the "scheme" of selectable variants, so we add selectable articles with the determined variants, that worked also.
But we have the same url-part (and lables) for the selectable and the variants. We can change the label but not the url part. I thought i could do this with "product.url" in mapping, but this does not work.
Is there a way to set the product.url in the import "manually"?
Thank you!
Ralf
Thanks a lot!
heural
Re: Product csv import: product.url
Post by heural » 09 Nov 2022, 13:48
Solved.
At the end of the import we retrieve the select articles resp. the variants and change the url of each variant.
Thanks a lot!
Post by aimeos » 10 Nov 2022, 06:39
"product.url" is also a property you can configure for your CSV import so you don't have to do that afterwards.
