Retrieving order with products
yeh
Post by yeh » 10 Nov 2022, 14:41
I have a parent site with many sub sites using the ai-sites extension. I have a decorator on jqadm/order/decorators/global that needs to be able to access all the products on an order even if they are attached to different sub-sites.
So when an order is saved on a particular sub-site, the decorator should look at all products from all sites and perform some actions.
To get the order with its associated products I am trying this:
$defaultSiteId = '1.';
$context = $this->context();
$item = $this->view()->item;
$context->locale()->setSiteId($defaultSiteId);
$orderBaseManager = \Aimeos\MShop::create( $context, 'order/base' );
$orderBase = $orderBaseManager->get($item->getId(), ['product']);
Although this does retrieve an $orderBase object, it doesn't load the products. What am I doing wrong?
Re: Retrieving order with products
Post by aimeos » 11 Nov 2022, 06:13
The domains to retrieve must be:
$orderBaseManager->get($item->getId(), ['order/base/product']);
yeh
Post by yeh » 15 Nov 2022, 11:21
great, thank you.
That works to retrieve the products, however the code is only retrieving products for the currently selected site. I am setting the locale site id earlier in the code, is there anything else I need to do to set the context to the default site rather than the site currently selected?
Post by aimeos » 16 Nov 2022, 10:15
If your context locale object is already using the "default" site, it will work as expected but I guess you are in a sub-site and want to get all orders from the "default" site and all it's sub-sites. You have to set a new locale to a cloned context:
$manager = \Aimeos\MShop::create( $context, 'locale' );
$context->setLocale( $manager->bootstrap( 'default', '', '' ) );
This is documented here:
https://aimeos.org/docs/latest/laravel/ ... os-objects
yeh
Post by yeh » 16 Nov 2022, 16:21
That is exactly what I need, thank you :)
