Querying package-weight property on basket
boettner
Post by boettner » 24 Sep 2015, 12:43
I´m trying to qery the basket weight property but can´t manage to setup a query taht is selecting the property value directly. As you can see I am currently looping over all properties to get the one in question:
	 * Returns the  weight dependend price
	 * @param MShop_Order_Item_Base_Interface $basket Basket object
	 * @return MShop_Price_Item_Interface Price item containing the price, shipping, rebate
	public function calcPrice(MShop_Order_Item_Base_Interface $basket) {
		$config       = $this->getServiceItem()->getConfig();
		$context      = $this->_getContext();
		$basketWeight = 0;
		$basketItems  = $basket->getProducts();
		foreach ($basketItems as $basketItem) {
			$propertyManager = MShop_Factory::createManager($context, 'Product/Property');
			$search = $propertyManager->createSearch(true);
			//			$expr   = array(
			//				$search->compare('==', 'product.property.type', 'package-weight'),
			//				$search->getConditions(),
			//			$search->setConditions($search->combine('&&', $expr));
			$properties = $propertyManager->searchItems($search);
			foreach ($properties as $property) {
				if ($property->getType() == 'package-weight') {
					if ($property->getValue() > 0) {
						$basketWeight += $property->getValue() * $basketItem->getQuantity();
		foreach ($config as $key => $costConf) {
			if ($basketWeight > (float) $costConf['min'] && $basketWeight <= (float) $costConf['max']) {
				$cost = $costConf['cost'];
		$price = $this->_getProvider()->calcPrice($basket);
		$price->setCosts($cost);
		return $price;
What am I missing here?
Best
Robert.
Re: Querying package-weight property on basket
Post by aimeos » 24 Sep 2015, 20:32
This will do the job efficiently:
	$basketWeight = 0;
	$prodMap = array();
	foreach ($basket->getProducts() as $basketItem) {
		$prodIds[$basketItem->getProductId()] = $basketItem->getQuantity();
	$propertyManager = MShop_Factory::createManager($context, 'product/property');
	$expr   = array(
		$search->compare('==', 'product.property.parentid', array_keys($prodMap)),
	foreach ($propertyManager->searchItems($search) as $property) {
		if (isset($prodMap[$property->getParentId()])) {
			$basketWeight += $property->getValue() * $prodMap[$property->getParentId()];
	if (isset($config['costs']) {
		foreach ((array) $config['costs'] as $key => $costConf) {
				break;
	$price->setCosts($price->getCosts() + $cost);
	return $price;
boettner
Post by boettner » 26 Oct 2015, 17:22
I changed the decorator for more clearness in backend. Every price is now one single service with the configuration options:
weight.min
weight.max
This way it is possible to combine the default country.billing decorator in one service object and it´s better readable for non tech admins. Before I had a JSON object combining the whole weight scale in a single delivery service.
Code is here:
https://gist.github.com/boettner-it/2d0 ... 457ba24a7b
Post by aimeos » 27 Oct 2015, 12:22
boettner wrote:I changed the decorator for more clearness in backend. Every price is now one single service with the configuration options
Code is here:
We would love to add this to the Aimeos Core. Could you create a pull request?
boettner
Post by boettner » 28 Oct 2015, 10:11
aimeos wrote: We would love to add this to the Aimeos Core. Could you create a pull request?
I just created the pull request, thanks for approving . :-)
