Supplier filter does not work
TGergo
Post by TGergo » 24 Nov 2022, 15:10
Hello!
The product is assigned to a supplier.
But when I look at the products of supplier, the list is empty
The relationship is bad?
Filtering does not work.
Aimeos Stable Version 2022.10.2
PHP version 8.1
Windows
Re: Supplier filter does not work
Post by aimeos » 25 Nov 2022, 10:24
Thanks for the hint!
The problem is now fixed in aimeos/ai-admin-jqadm:dev-master and aimeos/ai-admin-jqadm:2022.10.x-dev and will be part of the next release.
TGergo
Post by TGergo » 06 Jan 2023, 14:34
I look at the products of supplier, the list is no longer empty.
Thank You!
Filtering still does not work for me, with CSV imported data.
But when I upload a product by manual, it works.
The problem, CSV import does not insert to the mshop_index_supplier table.
I think admin works by mshop_product_list table, where domain column: supplier.
Can You try a Supplier import and a Product import, please? Does it work for you?
Post by aimeos » 06 Jan 2023, 14:56
The product importer doesn't update the index table. You have to execute the index/rebuild job afterwards.
TGergo
Post by TGergo » 06 Jan 2023, 15:01
Oh, Thank You!!!
