Checkout skips steps
TGergo
Post by TGergo » 13 Dec 2022, 14:38
php version 8.1
Windows 10
Aimeos version 2022.10.2.
Hello!
I would like to guide the registered customer through all the steps in the checkout.
But sometimes checkout button (/checkout) jumps to the last or other step but not the second one to enter the address.
aimeosenv
Re: Checkout skips steps
Post by aimeosenv » 13 Dec 2022, 21:41
If you are logged in it will redirect you to step 4. right away by default.
If you are not logged in it will go step by step.
Hope it helps.
Aimeos 2022.10+ (2022.10.3)
PHP 8.1.12 / Laravel
Win (Develop)
Post by aimeos » 14 Dec 2022, 07:12
Like @aimeosenv said, steps are skipped for already known subparts. If the user is logged in, the address step is skipped and if the user already ordered once, the delivery and payment steps are skipped too by default. You can adapt the later behavior in the Autofill plugin:
https://aimeos.org/docs/latest/manual/plugins/#autofill
TGergo
Post by TGergo » 14 Dec 2022, 10:58
Thank You!
I need to use Laravel registration too. (/register)
I know you don't support it.
Therefore this is a problem.
Post by aimeos » 15 Dec 2022, 12:19
If you want to use user registration/login before checkout, there's a thread with instructions how to do that:
Re: Login/Register forms within shop pages
