grapesjs as main website
mbnoimi
Post by mbnoimi » 17 Dec 2022, 07:25
I would like a website based on simple Laravel CMS one of its feature is renting services so eCommerce feature is not located in the home page.
Can I use grapesjs in this use case?
Re: grapesjs as main website
Post by aimeos » 19 Dec 2022, 08:39
Yes, you have to remove the "p" prefix for the routes of the pages here:
https://github.com/aimeos/aimeos/blob/m ... op.php#L40
Then, most likely there will be a conflict with the Laravel auth routes you have to solve.
