Site broken after running Composer up to update
Unfortunately my Site is broken after running Composer up to update.
Trying to access the site locally or the /admin page isn't working and just returning SQL Database errors
SQLSTATE[42S22]: Column not found: 1054 Unknown column 'mlocsi.rating' in 'field list': SELECT mlocsi."id" AS "locale.site.id", mlocsi."siteid" AS "locale.site.siteid", mlocsi."code" AS "locale.site.code", mlocsi."label" AS "locale.site.label", mlocsi."config" AS "locale.site.config","
Is there a way I can revert or fix this?
My .ENV file looks ok
I have also tried rebooting the server
Any help would be appreciated
Re: Site broken after running Composer up to update
I have just ran ./artisan aimeos:setup
my site is now back other than a few images which have been overwritten
If you upgrade from previous version, you should always execute the setup tasks to update your database too:
See: https://aimeos.org/docs/latest/laravel/setup/#upgrade
php artisan aimeos:setup
