Refused to load the script 'https://js.stripe.com/v3/' because it violates the following Content Security Policy directi
mhbhat
Post by mhbhat » 19 Jan 2023, 14:12
Hi, I tried to use the Stripe payment gateway but I got this error while checkout in the console. How to resolve this?
When I see the source code I noticed this:
<meta http-equiv="Content-Security-Policy" content="base-uri 'self'; default-src 'self' 'nonce-5xWW/yrW/7wM2G9eaucecQ=='; style-src &#039;unsafe-inline&#039; &#039;self&#039;; img-src &#039;self&#039; data: https://aimeos.org; frame-src https://www.youtube.com https://player.vimeo.com">
I guess it won't allow stripe so any clues?
Re: Refused to load the script 'https://js.stripe.com/v3/' because it violates the following Content Security Policy dir
Post by aimeos » 19 Jan 2023, 14:25
Please copy the Aimeos base.blade.php template to your ./resources/views/vendor/shop/ directory and change the CSP directive accordingly. Read also:
https://aimeos.org/docs/latest/laravel/ ... ity-policy
mhbhat
Post by mhbhat » 20 Jan 2023, 07:17
Thank you the environment was set to
local
I just set to
production
and this error got disappeared
Post by aimeos » 20 Jan 2023, 16:15
It should be the other way round and it's fixed here:
https://github.com/aimeos/aimeos-larave ... e6a783c3ed
The next release will contain the fix and then, you will get the error in non-debug mode if you don't adapt the CSP rule.
