Currency problems
NeroCastorena
Currency problems
Post by NeroCastorena » 27 Jan 2023, 22:37
Hi, i change the currency to MXN but the '','' and ''.'' are wrong, for example i need the price to show like this $1,912.00 mxn and instead it looks like this $1.912,00 mex, how can i fix this?
I'm using aimeos 2022 and php 8.1
Re: Currency problems
Post by aimeos » 28 Jan 2023, 12:12
The number formatting depends on the used language, not the currency and the PHP Intl extension is responsible for that formatting. As Mexico uses a different number formatting than Spain, you have to use "es_MX" as language to get the correct number formatting.
