Pre-order when stocklevel is 0
boettner
Post by boettner » 22 Oct 2015, 14:47
Hi again,
the second question for today is whether it´s possible to enable the regular order process even when stocklevel is zero and giving the customer a message at the checkout. Color coding the basket button in red should still be present to indicate on product level that the product is out of stock.
Robert.
Re: Pre-order when stocklevel is 0
Post by aimeos » 25 Oct 2015, 11:38
boettner wrote: the second question for today is whether it´s possible to enable the regular order process even when stocklevel is zero and giving the customer a message at the checkout. Color coding the basket button in red should still be present to indicate on product level that the product is out of stock.
You can configure that behavior: https://aimeos.org/docs/Configuration/C ... uire-stock
boettner
Post by boettner » 26 Oct 2015, 08:48
Hi aimeos,
overlooking documentation parts is truly embarassing. Sorry for that. Very often when I don´t find required information by browsing I´m using the search. But MediaWikis search results are then very often very large and many irrelevant results are included. So thanks agin.
Cheers
Robert.
