Rename menu item in Backend?
rowild
Post by rowild » 03 Mar 2023, 08:52
I would like to rename "Suppliers" to something else. Is that at all possible, and if so, how?
Re: Rename menu item in Backend?
Post by aimeos » 05 Mar 2023, 08:52
Yes, it can be translated to a different string. The translation domain is "admin" and the string "supplier". For TYPO3, this setting in the TSConfig may work:
module.tx_aimeos.settings.i18n.de.0 {
  domain = admin
  string = supplier
  trans = Hersteller
rowild
Post by rowild » 05 Mar 2023, 09:57
Thank you!
I have to place the snippet into the "Page tsConfig" field of the Shop root page, if I am not using a sitepackage, right? (As described here: https://docs.typo3.org/m/typo3/referenc ... getsconfig)
(In my case, that is the same site where the Aimeos Distribution includes its own ts-scripts.)
If so, then this does not work, the Aimeos backend still shows "Supplier".
I did upload a wrong image in my initial post, sorry for that. Here are the ones that show the "Supplier" string, where I would like to have it changed to sth else.
I tried this, since the menu item in the "Catalog" submenu is actually plural:
module.tx_aimeos.settings.i18n.en_US.0 {
  domain = admin
  string = supplier
  trans {
    0 = Event Organiser
    1 = Event Organisers
module.tx_aimeos.settings.i18n.en.0 {
  domain = admin
  string = supplier
  trans {
    0 = Event Organiser
  domain = admin
  string = supplier
  trans {
    0 = Veranstalter
    1 = Veranstalter
I also tried with "module" removed and, in another try, "plugin" instead of "module" as described in the Aimeos docu:
https://aimeos.org/docs/2022.x/typo3/cu ... nformation
But I assume that does not make sense at all, since I want to change things in the backend, which require the "module" prefix, right?
How do I find out if my installation uses "en" or "en_US"? (I used the Aimeos Distribution on a composer-installed TYPO3 11.)
rowild
Post by rowild » 07 Mar 2023, 11:21
...doesn't work in TYPO3 10 either...
Post by aimeos » 08 Mar 2023, 07:35
Seems like TS-based translations doesn't work here. Use Gettext translations instead:
https://aimeos.org/docs/latest/developer/translations/
