Typo3: 503 after upgrade aimeos
heural
Post by heural » 13 Mar 2023, 10:57
Hi Aimeos-Team,
after the upgrade from aimeos-core 2022.10.11 -> 12 and aimeos-typo3 22.10.5 -> 6
i got a 503 Error:
...\aimeos\\vendor\\aimeos\\aimeos-core\\src\\MShop\\Context.php","line":589,"message":"Argument 1 passed to Aimeos\\MShop\\Context::setToken() must be of the type string, null given
Thanks a lot!
Re: Typo3: 503 after upgrade aimeos
Post by aimeos » 13 Mar 2023, 20:17
That bug has been fixed in the upcoming 22.10.7. If you are using composer, can you do a "composer up" and check if it works then?
heural
Post by heural » 14 Mar 2023, 07:23
Yes it works,
thank you!
Thanks a lot!
