User Self Deletion (option)
briajer
Post by briajer » 30 Mar 2023, 13:20
What is the best way to implement the user deletion while they are logged in?
https://aimeos.org/docs/latest/frontend ... e-customer
I would like to have a button or link within the user account (bottom of page) with a secondary (are you sure) check.
The documentation just seems to show a CLI command but i'm looking for a solution in the front end UI.
Re: User Self Deletion (option)
Post by aimeos » 02 Apr 2023, 11:16
There's also example JS code in the second tab (jQuery)
briajer
Post by briajer » 04 Apr 2023, 16:34
if the cURL command is run in a script what is needed specifically in the CSP / CSRF?
i'm running into an issue where it won't run the script.
a nonce or ('nonce-...') is required to enable inline execution.
may also be connected to script-src default-src
Post by aimeos » 07 Apr 2023, 08:40
You can't use inline Javascript for security reasons. Instead, add your code to a .js file that's included in the page.
