Adding attributes through CSV and conditional attributes
Michael-0208
Post by Michael-0208 » 18 Apr 2023, 09:29
Hi All,
I have some queries
I want to upload the product's attributes CSV. Is it possible?
If I leave CSV's part apart
The attributes that are added to the product are conditional for eg. if I have a motherboard of ASUS then the Chipset of ASUS only will be available, not other chipsets for the user on the product page.
Re: Adding attributes through CSV and conditional attributes
Post by aimeos » 19 Apr 2023, 09:16
Uploading CSV files for attributes separately isn't possible, only in combination with products when using the Aimeos product CSV importer:
https://aimeos.org/docs/latest/cronjobs ... sv-import/
Attributes can have relations to other attributes using the mshop_attribute_list table. You can try to define your relations this way.
Michael-0208
Post by Michael-0208 » 19 Apr 2023, 09:33
Thank you so much for your reply!
