catalog Id in product/export job
xaxalex
Post by xaxalex » 23 Apr 2023, 13:01
Good afternoon.
Pls tell me how to get also its categories when exporting a product?
aimeos shop 2022.10, php 8.1. ubuntu 22.04
xaxalex
Re: catalog Id in product/export job
Post by xaxalex » 24 Apr 2023, 15:50
I see that the data is taken from 4 domains. To the shop catalog.php I also registered the domain 'like this:
'product' => [
   'export' => [
      'location' => 'my_path',
      'type' => 'csv',
      'domains' => [
         'catalog',
      'partials' => [
         'directory' => '"my_path"/packages/champion-theme/templates/controller/jobs/product/export/items-partial-catalog-standard.php ' ,
I also created a file items-partial-catalog-standard.php and also prescribed the full path to it in the configuration.
in the mshop_product_list table, where, as far as I understand, the product data comes from, there is the necessary line: catalog|default|17
however, after completing the task, I still do not receive this data.
Dear Aimeos team!
I ask for your help.
Post by aimeos » 26 Apr 2023, 06:20
Your configuration is probably at the wrong location. You have to add it either to your ./config/shop.php and use this structure:
'controller' => [
  'jobs' =>
    'product' => [
      'export' => [
        'type' => 'csv',
        'domains' => [
          'catalog', 'attribute', 'media', 'price', 'product', 'text'
        'partials' => [
          'directory' => 'my_path/packages/champion-theme/templates/controller/jobs/product/export/items-partial-catalog-standard.php ' ,
Or in your own project-specifc Aimeos extension you've created in ./config/controller.php as:
  'jobs' =>
    'product' => [
      'export' => [
        'type' => 'csv',
        'domains' => [
          'catalog' => 'catalog'
        'partials' => [
xaxalex
Post by xaxalex » 26 Apr 2023, 10:14
Good afternoon.
My configuration was in ./config/shop.php
I added the example you sent as well in controller.php in its extension.
Anyway, the catalog domain is missing.
it's my controller.php:
<?php
return [
    'common' => [
    'frontend' => [
    'jobs' => [
        'product' => [
            'export' => [
                'location' => 'my_path'/export.zip',
                'domains' => [
                    'catalog', 'attribute', 'media', 'price', 'product', 'text',
                'partials' => [
                    'catalog' => ''my_path'/packages/champion-theme/templates/controller/jobs/product/export/items-partial-catalog-standard.php',
            'import' => [
                'csv' => [
                    'location' => ''my_path'/import-product',
        'catalog' => [
            'import' => [
                'csv' => [
                    'location' => ''my_path'/import-category',
partials of product/export/items-body-standard.php
	<lists>
		<?php foreach ($item->getDomains() as $domain): ?>
            <?=print('@@@@' . $domain . '!!!!')?>
			<?=$this->partial(
    'product/export/items-partial-' . str_replace('/', '', $domain) . '-standard',
    ['listItems' => $item->getListItems($domain)]
		<?php endforeach?>
	</lists>
partials of product/export/items-partial-catalog-standard.php
<catalog>
	<?php foreach ($this->listItems as $listItem): ?>
        <?=print_r('!!! CATALOG !!!')?>
		<?php if ($refItem = $listItem->getRefItem()): ?>
            <?=print_r('!!! DOMAIN !!!')?>
		<?php endif?>
	<?php endforeach?>
</catalog>
I can't figure out what's the problem
Post by aimeos » 29 Apr 2023, 07:35
Seems to be OK. Keep in mind that configuration in ./config/shop.php overwrites configuration if your own extensions.
First I would check if the list of domains really contains "catalog" here:
https://github.com/aimeos/ai-controller ... d.php#L471
