Cannot connect to the database - An exception occurred in the driver: SQLSTATE[HY000] [2002] Connection refused
cshelswell
Hi - I'm really hoping someone might be able to help me with this as I've been struggling for days.
For some reason no matter what I do when I perform an install and either use Docker and "sail up" or if I use "php artisan serve" I get the error:
I can login to the DB no problem using Sequel Pro, the migrations all work through the terminal.
After install I perform "sail up" then I can provide the correct details for the DB connection as per my docker-composer.yml file and my .env file but I just can't get the browser past that error message.
My docker-compose.yml file is:
I've tried using the standard Mysql driver as well but same problem. My .env file is:
Any help would be very gratefully received - Thanks so much.
An exception occurred in the driver: SQLSTATE[HY000] [2002] Connection refused: SET SESSION sort_buffer_size=2097144; SET NAMES 'utf8mb4'; SET SESSION sql_mode='ANSI'
# For more information: https://laravel.com/docs/sail
version: '3'
services:
laravel.test:
build:
context: ./vendor/laravel/sail/runtimes/8.1
dockerfile: Dockerfile
args:
WWWGROUP: '${WWWGROUP}'
image: sail-8.1/app
extra_hosts:
- 'host.docker.internal:host-gateway'
ports:
- '${APP_PORT:-80}:80'
- '${VITE_PORT:-5173}:${VITE_PORT:-5173}'
environment:
WWWUSER: '${WWWUSER}'
LARAVEL_SAIL: 1
XDEBUG_MODE: '${SAIL_XDEBUG_MODE:-off}'
XDEBUG_CONFIG: '${SAIL_XDEBUG_CONFIG:-client_host=host.docker.internal}'
volumes:
- '.:/var/www/html'
networks:
- sail
depends_on:
- mariadb
- redis
- meilisearch
- minio
- selenium
mariadb:
image: 'mariadb:10.4'
ports:
- '${FORWARD_DB_PORT:-3306}:3306'
environment:
MYSQL_ROOT_PASSWORD: '${DB_PASSWORD}'
MYSQL_ROOT_HOST: "%"
MYSQL_DATABASE: '${DB_DATABASE}'
MYSQL_USER: '${DB_USERNAME}'
MYSQL_PASSWORD: '${DB_PASSWORD}'
MYSQL_ALLOW_EMPTY_PASSWORD: 1
volumes:
- 'sail-mariadb:/var/lib/mysql'
- './vendor/laravel/sail/database/mysql/create-testing-database.sh:/docker-entrypoint-initdb.d/10-create-testing-database.sh'
networks:
- sail
healthcheck:
test: ["CMD", "mysqladmin", "ping", "-p${DB_PASSWORD}"]
retries: 3
timeout: 5s
redis:
image: 'redis:alpine'
ports:
- '${FORWARD_REDIS_PORT:-6379}:6379'
volumes:
- 'sail-redis:/data'
networks:
- sail
healthcheck:
test: ["CMD", "redis-cli", "ping"]
retries: 3
timeout: 5s
memcached:
image: 'memcached:alpine'
ports:
- '11211:11211'
networks:
- sail
meilisearch:
image: 'getmeili/meilisearch:latest'
ports:
- '${FORWARD_MEILISEARCH_PORT:-7700}:7700'
volumes:
- 'sail-meilisearch:/meili_data'
networks:
- sail
healthcheck:
test: ["CMD", "wget", "--no-verbose", "--spider", "http://localhost:7700/health"]
retries: 3
timeout: 5s
minio:
image: 'minio/minio:latest'
ports:
- '${FORWARD_MINIO_PORT:-9000}:9000'
- '${FORWARD_MINIO_CONSOLE_PORT:-8900}:8900'
environment:
MINIO_ROOT_USER: 'sail'
MINIO_ROOT_PASSWORD: 'password'
volumes:
- 'sail-minio:/data/minio'
networks:
- sail
command: minio server /data/minio --console-address ":8900"
healthcheck:
test: ["CMD", "curl", "-f", "http://localhost:9000/minio/health/live"]
retries: 3
timeout: 5s
mailhog:
image: 'mailhog/mailhog:latest'
ports:
- '${FORWARD_MAILHOG_PORT:-1025}:1025'
- '${FORWARD_MAILHOG_DASHBOARD_PORT:-8025}:8025'
networks:
- sail
selenium:
image: 'selenium/standalone-chrome'
volumes:
- '/dev/shm:/dev/shm'
networks:
- sail
networks:
sail:
driver: bridge
volumes:
sail-mariadb:
driver: local
sail-redis:
driver: local
sail-meilisearch:
driver: local
sail-minio:
driver: local
APP_NAME=Aimeos
APP_ENV=local
APP_KEY=base64:OVsDA6nbFW6JevYFnrQLWdsfTzP0bTp6XUMt0Y7qJTc=
APP_DEBUG=1
APP_VERSION=1
APP_URL=http://localhost:8000
#ASSET_URL=http://localhost:8000
SHOP_MULTILOCALE=
SHOP_MULTISHOP=
SHOP_REGISTRATION=
SHOP_PERMISSION=admin
LOG_CHANNEL=stack
DB_CONNECTION=mysql
DB_HOST=127.0.0.1
DB_PORT=3306
DB_DATABASE=amazon_shops
DB_USERNAME=forge
DB_PASSWORD=forge
BROADCAST_DRIVER=log
CACHE_DRIVER=file
QUEUE_CONNECTION=sync
SESSION_DRIVER=file
SESSION_LIFETIME=120
REDIS_HOST=127.0.0.1
REDIS_PASSWORD=
REDIS_PORT=6379
MAIL_MAILER=smtp
MAIL_HOST=smtp.mailtrap.io
MAIL_PORT=2525
MAIL_USERNAME=
MAIL_PASSWORD=
MAIL_ENCRYPTION=
AWS_ACCESS_KEY_ID=
AWS_SECRET_ACCESS_KEY=
AWS_DEFAULT_REGION=us-east-1
AWS_BUCKET=
PUSHER_APP_ID=
PUSHER_APP_KEY=
PUSHER_APP_SECRET=
PUSHER_APP_CLUSTER=mt1
MIX_PUSHER_APP_KEY=
MIX_PUSHER_APP_CLUSTER=
Re: Cannot connect to the database - An exception occurred in the driver: SQLSTATE[HY000] [2002] Connection refused
The "connection refused" message from MySQL is not about wrong credentials but it seems that the host name/IP and/or port is not right one.
cshelswell
Thank you so much for your quick response.
I've tried changed ports / URLs etc but still end up with the same message. On a couple of occasions I've managed to get it to load the /admin page but even after creating the user it won't log in.
It's getting a bit late here in New Zealand so I think I'll probably attack it again tomorrow and let you know my findings.
I'm sure it'll be something really simple that I've just overlooked, that always tends to be the case in situations like this
Thanks again
Thanks again
