Add to basket after checkout ??
zcqay
Post by zcqay » 14 May 2023, 16:50
hello,
May you check this behaviour?
Order finished : https://prnt.sc/nURZq8lJdjNn
order details with the ability to add to basket !!!! :shock: , why is that? may you please explain?
https://prnt.sc/sBC4L5I028kA
adamtang
Re: Add to basket after checkout ??
Post by adamtang » 15 May 2023, 04:54
What happened if you click that button?
Post by aimeos » 16 May 2023, 06:52
Customers can easily buy products again and if you click on the "add to basket" button, the products from the order will be simply added to the current basket.
adamtang
Post by adamtang » 16 May 2023, 12:44
aimeos wrote: 16 May 2023, 06:52 Customers can easily buy products again and if you click on the "add to basket" button, the products from the order will be simply added to the current basket.
I have this similar feature on my other e-commerce project before.
