I want to import JSON links and save to the database, and how to make my own controller
RyadShaker
Post by RyadShaker » 20 May 2023, 16:07
environment (Win)
PHP version 8.0
Re: I want to import JSON links and save to the database, and how to make my own controller
Post by aimeos » 21 May 2023, 08:00
Can you please explain in more details what you want to do and why?
RyadShaker
Post by RyadShaker » 21 May 2023, 08:59
I have a store. I want to export products from my store as JSON and import them into aimeos
Post by aimeos » 21 May 2023, 09:23
To import JSON data, you would have to create your own importer. If you can export XML from your current store, it can be imported using the Aimeos XML importers:
https://aimeos.org/docs/latest/cronjobs ... ml-import/
