Get product and catalog from order/product in confirmation template
heural
Post by heural » 30 May 2023, 14:26
Hi Aimeos-Teams,
for google tag manager tracking purposes, I need the catalog(s) in the order confirmation template (client/html/checkout/confirm/body) for each product.
Is there a way to retrieve the product item "MShop/Product/Item/Standard" and the attached catalog(s) withhin the iteration from $this->summaryBasket->getProducts() in this template?
Thank you!
Thanks a lot!
Re: Get product and catalog from order/product in confirmation template
Post by aimeos » 31 May 2023, 08:59
You have to create a decorator which fetches the product items including the categories for the ordered products in the basket and pass that to the view:
https://aimeos.org/docs/latest/frontend ... omponents/
In 2023.07+, you will be able to configure which related domains are loaded:
https://github.com/aimeos/ai-client-htm ... #L124-L140
heural
Post by heural » 31 May 2023, 09:37
Ok thank you.
That are my thoughts also, but in the docu/configure there are no decorator-params for html-client/checkout/confirm,
only overwrite the standard impl: https://aimeos.org/docs/latest/config/c ... firm/#name
So that should be: client/html/checkout/confirm/decorators/(global|local|excludes)
For understanding: have all html-client objects these decorator pattern and the docu is missing that in some places?
e.g. the basket-mini have it:
https://aimeos.org/docs/latest/config/c ... decorators
Thanks a lot!
Post by aimeos » 31 May 2023, 10:49
Decorators can be applied to any HTML client component. The missing documentation has been added again in the code and will be available on the web site with the next release.
