cache issue
KhushalWebroot
cache issue
Post by KhushalWebroot » 01 Jun 2023, 10:19
Hi
All files are being cached. I believe it is being stored in the root storage folder.Would you be able to tell me how to clear the cache for all full applications by cmd or in any other manner.
php artisan cache:clear
php artisan aimeos:clear
php artisan config:cache
these dosn't help.
Re: cache issue
Post by aimeos » 03 Jun 2023, 11:22
To clear all caches in Laravel use:
php artisan optimize:clear
For Aimeos use:
For development, you can disable caching completely changing these config settings:
- https://github.com/aimeos/aimeos/blob/m ... p.php#L196
- https://github.com/aimeos/aimeos/blob/m ... p.php#L152
