How to override Aimeos\Controller\Common\Media add() function.
AnujMagar
Post by AnujMagar » 19 Jun 2023, 18:05
I'm on using Laravel 9, Aimeos 2022.x and PHP 8.1 on linux
I need to customize the behavior of the add() function in the Aimeos\Controller\Common\Media class using extension. However, I'm unsure about the correct approach to override this function.
Specifically, I want to extend the functionality of the add() method in order to perform blurhash of $file when adding a new media item.
Re: How to override Aimeos\Controller\Common\Media add() function.
Post by aimeos » 21 Jun 2023, 14:27
You can create your own common media controller class with a new name (e.g. "Mymedia") and extend from the "Standard" class:
<?php
namespace Aimeos\Controller\Common\Media;
class Mymedia extends Standard
	public function add( \Aimeos\MShop\Media\Item\Iface $item, \Psr\Http\Message\UploadedFileInterface $file ) : \Aimeos\MShop\Media\Item\Iface
		// own implementation
Then, configure the new class to be used:
controller/common/media/name = Mymedia
How to add configuration depends on the use framework. For Laravel it's in ./config/shop.php:
'controller' => [
	'common' => [
		'media' => [
			'name' => 'Mymedia'
