APP_SHOP_MADMIN_CACHE_MANAGER Category Problem
OksanaBulgakova
Post by OksanaBulgakova » 05 Jul 2023, 15:10
When I enable this APP_SHOP_MADMIN_CACHE_MANAGER=Standard - category pages are not loading - when selecting any category, it just loads the same category listing page.
"php": "^7.3|^8.0",
"aimeos/aimeos-laravel": "~2020.10"
Re: APP_SHOP_MADMIN_CACHE_MANAGER Category Problem
Post by aimeos » 05 Jul 2023, 15:17
Do you mean the "madmin/cache/manager/name = Standard" configuration?
Please also note that 2020.10 is not supported any more and you should upgrade to 2023.x or buy ELTS support from the Aimeos company: https://aimeos.com/support#c428
OksanaBulgakova
Post by OksanaBulgakova » 05 Jul 2023, 15:41
Yes, I mean this "madmin/cache/manager/name = Standard" configuration.
My client's last order was 03/23/2021.
And I see this: "Duration 1 year support + updates".
Does "+updates" mean I can upgrade to 2023.x now? Or we should only make another order?
Post by aimeos » 05 Jul 2023, 16:08
OksanaBulgakova wrote: 05 Jul 2023, 15:41 Yes, I mean this "madmin/cache/manager/name = Standard" configuration.
Clear the Aimeos content cache which depends on your host application how to do that (Laravel/TYPO3).
OksanaBulgakova wrote: 05 Jul 2023, 15:41 My client's last order was 03/23/2021.
If you have bought any extensions from the Aimeos company, you need to buy at least another year of support because the one year support period was over 03/23/2022.
