Category is not display in header after added on admin side.
aimeo.alpesh
Post by aimeo.alpesh » 06 Jul 2023, 13:33
Getting issue that Category not found added from admin panel.
It display only if i logged to website.
Without login i am not getting latest added category.
Is there caching issue or what?
Can you please advice on it.
Many Thanks.
Re: Category is not display in header after added on admin side.
Post by aimeos » 10 Jul 2023, 09:35
We've improved the cache invalidation and now, if you add, remove or change categories, the categories in the header are updated accordingly. For that, you need at least aimeos/aimeos-core:2023.07.2 and aimeos/ai-client-html:2023.07.2 packages.
