Integrating DHL Service
Aimeos Version: "2023.04",
PHP Version : "8.0.11",
Laravel version: "^10.0"
I want to use DHL Delivery Service in my Aimeos project. I created a service provider named as DhlServiceProvider.php.
I also add provide in config/service.php file. This is my service.php file code:->
After that In adminpanel for my DHL service, I selected provider as DHLServiceProvider. I have added Log::debug in my provider to debug whether it is reaching there at time of checkout. But it isn't.
Can you please guide if I am missing anything?
Thankyou
public function push(iterable $orders): \Aimeos\Map
Log::debug('Push method started');
$responseMap = new \Aimeos\Map();
foreach ($orders as $order) {
if ($order instanceof OrderItem) {
Log::debug('Processing order: ' . $order->getId());
Log::debug('Push method finished');
return $responseMap;
'services' => [
'shipping' => [
'dhl' => [
'decorator' => [
'Dhl' => ['Aimeos\\MShop\\Service\\Provider\\Delivery\\DhlServiceProvider']
Thankyou
Re: Integrating DHL Service
This is unnecessary and won't have any effect.davin wrote: ↑08 Aug 2023, 13:28 I also add provide in config/service.php file. This is my service.php file code:->Code: Select all
'services' => [ 'shipping' => [ 'dhl' => [ 'decorator' => [ 'Dhl' => ['Aimeos\\MShop\\Service\\Provider\\Delivery\\DhlServiceProvider'] ] ], ], ],
The push() method is called when you execute the order/service/delivery job controller. For Laravel, it's:
php artisan aimeos:jobs order/service/deliveryProfessional support and custom implementation are available at Aimeos.com
Which method should I use then? I just need to hit an API to send orderdata to DHL when order is completed and delivery service is DHL?
Can you please let me know, what changes I need to do to achieve this?
Everything is correct, you only have to execute the mentioned job controller.
Aimeos uses async cronjobs for performance and reliability reasons instead of performing potentially long running tasks in user requests.
Okay, so I have to run following on cronjob where it will check for new orders and call API for each. Right?
Correct
