Change basket data in basket plugin
heural
Post by heural » 14 Aug 2023, 09:13
Hi Aimeos-Team,
we change some custom data at the "setOrder.before"-event to the basket. That works fine so far, but for example we have paypal as the payment provider and we cancel the payment (backlink to our website ) the order is also canceled in aimeos - new order-(base)-id etc. is created if we checkout again.
But now the custom data from the previous checkout try is missing. It seems the data is not persited in the "session basket", it works only for the "save-the-order-to-database"-way. How can I change/add the custom data in this event to the "session basket" also?
 public function update( \Aimeos\MW\Observer\Publisher\Iface $basket, $event, $value = null )
        if ($event == 'setOrder.before') {
		$external_userid = <user-has-external-user-id>
                foreach($basket->getProducts() as $pos => $product) {
                            $product->setProjectUser($external_userid);
                            $basket->deleteProduct($pos);
                            $basket->addProduct($product);
Thank you!
Ralf
Thanks a lot!
Re: Change basket data in basket plugin
Post by aimeos » 16 Aug 2023, 13:10
That's true, the "setOrder.before" event is only published in the store() method of the basket frontend controller:
https://github.com/aimeos/ai-controller ... d.php#L289
Thus, the changes are not persisted into the session but only in the database.
There are two options now:
1.) Use another event like "addProduct.before/setProducts.before" to change the product when they are added
2.) Call save() of the basket controller in the HTML client to store the basket in the session too:
https://github.com/aimeos/ai-client-htm ... d.php#L211
heural
Post by heural » 17 Aug 2023, 14:12
Thank you!
I have another solution found, getting the session-basket and and set the data there:
  $manager = \Aimeos\MShop::create( $context, 'order/base' );
  $sessionBasket = $manager->getSession( 'default' );
  foreach($sessionBasket->getProducts() as $pos => $product) {
                            $sessionBasket->deleteProduct($pos);
                            $sessionBasket->addProduct($product);
Thanks a lot!
