Simple solution to improve the Aimeos documentation
akropivko
Post by akropivko » 26 Aug 2023, 16:00
Hello guys,
Since the Aimeous docs sometime contains inaccuracies (maybe it's because of several versions, etc.) I'd like to suggest a simple improvement: something like "See mistake? Highlight it and press [hotkeys]". And maybe plus a field with suggestion/edited text.
thanks for your work!
Re: Simple solution to improve the Aimeos documentation
Post by aimeos » 27 Aug 2023, 07:34
On the top right of each page is a pencil icon which opens the page at Github where you can make changes :-)
