Aimeos Laravel Extension integration
tiolierobin
Post by tiolierobin » 01 Sep 2023, 01:27
aimeos/aimeos-laravel: 2023.07
laravel/framework: 10.10
php version 8.2.8
Hi, I am trying to create Aimeos Extension locally by following the step here: https://aimeos.org/docs/2023.x/developer/extensions/ and generating it from the Extension Builder here: https://aimeos.org/extensions/
I already add the repositories section in my composer.json
    "repositories": [{
        "type": "composer",
        "url": "https://packages.aimeos.org/aimeoscom"
        "type": "path",
        "url": "packages/*"
but when i am running composer req aimeos-extensions/myextension
it shows error: Could not find a version of package aimeos-extensions/myextension matching your minimum-stability (stable). Require it with an explicit version constraint allowing its desired stability
this is the generated composer.json inside myextension package:
	"name": "aimeos-extensions/myextension",
	"description": "Aimeos myextension extension",
	"keywords": ["aimeos", "extension"],
	"type": "aimeos-extension",
	"license": "LGPL-3.0",
	"prefer-stable": true,
	"minimum-stability": "dev",
	"require": {
		"php": "^8.0.11",
		"aimeos/aimeos-core": "^2023.04"
	"require-dev": {
		"phpunit/phpunit": "~9.0||~10.0"
	"autoload": {
		"psr-4": {
			"Aimeos\\": "src"
		"classmap": [
			"src"
	"autoload-dev": {
		"psr-4": {
			"Aimeos\\": "tests"
		"classmap": [
			"tests"
and this is my composer.json in my laravel aimeos project:
    "name": "laravel/laravel",
    "type": "project",
    "description": "The skeleton application for the Laravel framework.",
    "keywords": ["laravel", "framework"],
    "license": "MIT",
    "require": {
        "php": "^8.1",
        "aimeos/aimeos-laravel": "~2023.07",
        "guzzlehttp/guzzle": "^7.2",
        "laravel/breeze": "^1.23",
        "laravel/framework": "^10.10",
        "laravel/sanctum": "^3.2",
        "laravel/tinker": "^2.8"
    "require-dev": {
        "fakerphp/faker": "^1.9.1",
        "laravel/pint": "^1.0",
        "laravel/sail": "^1.18",
        "mockery/mockery": "^1.4.4",
        "nunomaduro/collision": "^7.0",
        "phpunit/phpunit": "^10.1",
        "spatie/laravel-ignition": "^2.0"
    "autoload": {
        "psr-4": {
            "App\\": "app/",
            "Database\\Factories\\": "database/factories/",
            "Database\\Seeders\\": "database/seeders/"
    "autoload-dev": {
        "psr-4": {
            "Tests\\": "tests/"
    "scripts": {
        "post-autoload-dump": [
            "Illuminate\\Foundation\\ComposerScripts::postAutoloadDump",
            "@php artisan package:discover --ansi"
        "post-update-cmd": [
            "@php artisan vendor:publish --tag=laravel-assets --ansi --force",
            "@php artisan migrate",
            "@php artisan vendor:publish --tag=public --force",
            "\\Aimeos\\Shop\\Composer::join"
            "@php -r \"file_exists('.env') || copy('.env.example', '.env');\""
        "post-create-project-cmd": [
            "@php artisan key:generate --ansi"
    "extra": {
        "laravel": {
            "dont-discover": []
    "config": {
        "optimize-autoloader": true,
        "preferred-install": "dist",
        "sort-packages": true,
        "allow-plugins": {
            "pestphp/pest-plugin": true,
            "php-http/discovery": true
    "minimum-stability": "stable",
    "repositories": [{
        "type": "composer",
        "type": "path",
        "url": "packages/*"
anyone know what am I missing here? thankyou !
Re: Aimeos Laravel Extension integration
Post by aimeos » 01 Sep 2023, 06:23
Did you extract the extension zip file into packages/myextension/ directory?
tiolierobin
Post by tiolierobin » 01 Sep 2023, 07:40
yess, its already in folder, not a zip anymore
Post by aimeos » 01 Sep 2023, 07:48
Change in your main composer.json:
to:
tiolierobin
Post by tiolierobin » 01 Sep 2023, 07:53
yeay, its working. thankyou !
