[SOLVED] Cannot overwrite some template/view
unknow76616
I am trying to overwrite the template with my own custom template in my extension theme (). However, the original template is still being rendered, even after I have successfully installed my extension and cleared the cache with php artisan aimeos:clear.
I have already tried the following:
Customizing index.blade.php in the packages/<my-ext>/views/jqadm/ directory.
Making sure that the contents of my custom template are correct.
Clearing the cache with
However, the original template is still being rendered.
Can anyone please help me to resolve this issue?
Additional information:
I have tried Overwriting other templates in my extension theme and it has worked fine.
PHP: 8.2
env: Linux
vendor/aimeos/aimeos-laravel/views/jqadm/index.blade.phpCode: Select all
packages/<my-ext>/views/jqadm/index.blade.phpI have already tried the following:
php artisan aimeos:clear.Can anyone please help me to resolve this issue?
PHP: 8.2
env: Linux
Re: Cannot overwrite some template/view
Backend templates can not be overwritten by Aimeos theme packages. Instead, you have to use the standard Laravel directory for that (./resources/views/vendor/shop/jqadm).
unknow76616
[SOLVED] Thanks for your reply. It works! I wrote a positive review for your team on Trustpilot
Thanks a lot!alababdiy wrote: 26 Sep 2023, 17:39 [SOLVED] Thanks for your reply. It works! I wrote a positive review for your team on Trustpilot!
