Customize label for Attribute Type
BrianMecler
Post by BrianMecler » 30 Sep 2023, 20:41
Laravel Framework 10.13.1, php8.1-fpm, aimeos/aimeos-laravel 2023.04.2
I created a selection product which consists of two articles which of of the type 'Interval'. On the product page, the label 'Interval' is shown above the dropdown list to select the articles. Is there a way to customize the label above the dropdown to show different text?
I tried creating my own type, and see that the front end displays the code and not the label. And I cant use spaces in the code.
Re: Customize label for Attribute Type
Post by aimeos » 02 Oct 2023, 12:56
You have to translate the attribute type codes, e.g. in your ./config/shop.php.
See:
- https://aimeos.org/docs/latest/laravel/ ... anslations
- https://github.com/aimeos/ai-client-htm ... te.php#L95
The translation domain is "client/code".
