CSV Import attribute INSERT INTO "mshop_product_list" Duplicate entry
TGergo
Post by TGergo » 11 Oct 2023, 07:40
Hello!
I would like to run the CSV import multiple times.
I set the update to change the following attributes.
'controller' => [
	'product' => [
                   'import' => [
                       'csv' => [
                           'processor' => [
			       // modify by update import
                               'attribute' => [
                                   'listtypes' => [
                                       'myattribute1',
                                       'myattribute2'
Then I get the following error:
Unable to import product with code "2": SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry '125124-attribute-default-65287-1.' for key 'mshop_product_list.unq_msproli_pid_dm_ty_rid_sid':
INSERT INTO "mshop_product_list" (
"parentid", "key", "type", "domain", "refid", "start", "end",
"config", "pos", "status", "mtime", "editor", "siteid", "ctime"
) VALUES (
I tried to find the cause of the error, but so far I have not succeeded.
to:
INSERT IGNORE INTO "mshop_product_list"
But this is not a permanent solution.
Thanks if you have any ideas.
TGergo
PHP 8.1
"aimeos/aimeos-laravel": "^2022.10",
Windows + Homestead Vagrant Linux
Re: CSV Import attribute INSERT INTO "mshop_product_list" Duplicate entry
Post by aimeos » 12 Oct 2023, 08:56
Does that also occur if you remove your "listtypes" configuration?
TGergo
Post by TGergo » 12 Oct 2023, 12:50
No, if I take it out, it runs flawlessly.
TGergo
Post by TGergo » 17 Oct 2023, 07:14
Other problem with this feature.
When I add an attribute to the array
for example: 'myattribute1'
the first value is: text1
I change the value in the csv file: text2
will add text2 but not delete text1
so I have two values:
myattribute1 : text1
myattribute1 : text2
but my csv file contains only one
Post by aimeos » 19 Oct 2023, 10:01
Your configuration is wrong and must be:
	'controller' => [
		'jobs' => [
			'product' => [
				'import' => [
					'csv' => [
						'attribute' => [
							'listtypes' => ['myattribute1', 'myattribute2'],
TGergo
Post by TGergo » 24 Oct 2023, 07:54
Thanks! That was the problem.
TGergo
Post by TGergo » 26 Oct 2023, 11:33
TGergo wrote: 24 Oct 2023, 07:54 Thanks! That was the problem.
Another problem
It worked on my local machine but not on the test server.
same error, did not delete the old attributes
the solution: change Redis queue worker numprocs=2 to numprocs=1
TGergo
Post by TGergo » 27 Oct 2023, 07:22
aimeos wrote: 19 Oct 2023, 10:01 Your configuration is wrong and must be:
	'controller' => [
		'jobs' => [
			'product' => [
				'import' => [
					'csv' => [
						'attribute' => [
No, I think the documentation is also bad, this is the right one:
controller/common/product/import/csv/processor/attribute/listtypes
Post by aimeos » 28 Oct 2023, 09:30
At the moment, both are working:
https://github.com/aimeos/ai-controller ... hp#L72-L73
In 2024+, the "controller/common/..." setting will be removed.
