what is the difference between extension and theme?
i made an extension named rosen(Aimeos 2023.x extension),and a theme named rosentheme(Laravel theme 2023.x extension),
they have two different cmd:
but when i make a change to
\myshop\packages\rosentheme\themes\client\html\rosentheme\aimeos.css or \myshop\packages\rosen\themes\client\html\rosen\aimeos.css ,
both of them not work :
i tried
still the same problem.
which one should i use?
i need to chage some
css(for header),
templates\client\html\catalog\detail(for product details),
vendor\aimeos\aimeos-core\config\controller.php(for img not render to too small) and \myshop\resources\views\vendor\shop\base.blade.php(for nav and foot views).
also, how can i remove the installed rosen and rosentheme?
(i used to change aimeos directly,and want to move to the recommend way)
aimeos - 2023.x(https://github.com/aimeos/aimeos)
php8.2.4
Nginx ,MariaDB
composer req aimeos-extensions/rosen
composer req aimeos-themes/rosenthemebut when i make a change to
2023-10-19 10:42:52 /vendor/shop/themes/default/app.js?v=1 .................................................... ~ 0s
2023-10-19 10:42:52 /vendor/shop/themes/default/aimeos.js?v=1 ................................................. ~ 0s
2023-10-19 10:42:52 /vendor/shop/themes/rosentheme/locale-select.js?v=1 ....................................... ~ 0s
2023-10-19 10:42:52 /vendor/shop/themes/rosentheme/catalog-home.js?v=1 ........................................ ~ 0s
2023-10-19 10:42:52 /vendor/shop/themes/rosentheme/cms-page.js?v=1 ............................................ ~ 0s
2023-10-19 10:42:52 /vendor/shop/themes/rosentheme/catalog-filter.js?v=1 ...................................... ~ 0s
2023-10-19 10:42:52 /vendor/shop/themes/rosentheme/slider.js?v=1 .............................................. ~ 0s
2023-10-19 10:42:52 /vendor/shop/themes/rosentheme/catalog-lists.js?v=1 ....................................... ~ 0s
php artisan aimeos:clear
php artisan cache:clear
css(for header),
php8.2.4
Nginx ,MariaDB
Re: what is the difference between extension and theme?
An Aimeos extension should be used if you don't want to create your own theme but need to overwrite only templates and/or add custom classes.
Aimeos theme extensions are required if you want to create a custom theme and they already contain the same structure and code of an Aimeos extension, so you don't need both. The theme of an Aimeos theme extension needs to be configured in the Settings panel of the admin backend.
In your HTML, there seems to be a mix of default and rosentheme CSS/JS files for an unknown reason. What's the output of "composer show"?
You can remove the Aimeos extension and theme by removing them from your composer.json, run "composer up" and delete the directores in ./packages/ and ./public/shop/themes/
Warning to everybody:
You will burn in (developers) hell if you are changing files in the ./vendor directory!
shoul i remove these lines from D:\myshop\composer.json to uninstall theme and extensions?
then,run "composer up" and delete the directores in ./packages/ and ./public/shop/themes/
"repositories": [{
"type": "composer",
"url": "https://packages.aimeos.org/aimeoscom"
"type": "path",
"url": "packages/*"
PS D:\myshop> composer show
aimeos-extensions/rosen dev-main Aimeos rosen extension
aimeos-themes/rosentheme dev-main Aimeos rosentheme theme
aimeos/ai-admin-graphql 2023.10.1 Aimeos Admin GraphQL API extension
aimeos/ai-admin-jqadm 2023.10.3 Aimeos VueJS+Bootstrap admin backend
aimeos/ai-admin-jsonadm 2023.10.1 Aimeos JSON admin API for backend
aimeos/ai-client-html 2023.10.3 Aimeos standard HTML frontend
aimeos/ai-client-jsonapi 2023.10.2 Aimeos frontend JSON REST API
aimeos/ai-cms-grapesjs 2023.10.2 Aimeos GrapesJS CMS extension
aimeos/ai-controller-frontend 2023.10.2 Aimeos business controller logic for frontend
aimeos/ai-controller-jobs 2023.10.2 Aimeos job controllers for long running tasks
aimeos/ai-laravel 2023.10.1 Laravel adapter for Aimeos e-commerce integration
aimeos/aimeos-base 2023.10.2 Aimeos base layer for abstracting from host environments
aimeos/aimeos-core 2023.10.2 Full-featured e-commerce components for high performance ...
aimeos/aimeos-laravel 2023.10.x-dev e09f6da Professional, full-featured and high performance Laravel ...
aimeos/macro 1.0.0 Dynamically extend objects by custom methods
aimeos/map 3.5.0 Easy and elegant handling of PHP arrays as array-like col...
aimeos/upscheme 0.8.8 Database schema upgrades made easy
brick/math 0.11.0 Arbitrary-precision arithmetic library
dflydev/dot-access-data v3.0.2 Given a deep data structure, access data by dot notation.
doctrine/cache 2.2.0 PHP Doctrine Cache library is a popular cache implementat...
doctrine/dbal 3.7.1 Powerful PHP database abstraction layer (DBAL) with many ...
doctrine/deprecations v1.1.1 A small layer on top of trigger_error(E_USER_DEPRECATED) ...
doctrine/event-manager 2.0.0 The Doctrine Event Manager is a simple PHP event system t...
doctrine/inflector 2.0.8 PHP Doctrine Inflector is a small library that can perfor...
doctrine/lexer 3.0.0 PHP Doctrine Lexer parser library that can be used in Top...
dragonmantank/cron-expression v3.3.3 CRON for PHP: Calculate the next or previous run date and...
egulias/email-validator 4.0.1 A library for validating emails against several RFCs
enshrined/svg-sanitize 0.15.4 An SVG sanitizer for PHP
fakerphp/faker v1.23.0 Faker is a PHP library that generates fake data for you.
filp/whoops 2.15.3 php error handling for cool kids
fruitcake/php-cors v1.2.0 Cross-origin resource sharing library for the Symfony Htt...
graham-campbell/result-type v1.1.1 An Implementation Of The Result Type
guzzlehttp/guzzle 7.8.0 Guzzle is a PHP HTTP client library
guzzlehttp/promises 2.0.1 Guzzle promises library
guzzlehttp/psr7 2.6.1 PSR-7 message implementation that also provides common ut...
guzzlehttp/uri-template v1.0.2 A polyfill class for uri_template of PHP
hamcrest/hamcrest-php v2.0.1 This is the PHP port of Hamcrest Matchers
laminas/laminas-diactoros 3.2.0 PSR HTTP Message implementations
laravel/breeze v1.24.1 Minimal Laravel authentication scaffolding with Blade and...
laravel/framework v10.27.0 The Laravel Framework.
laravel/pint v1.13.3 An opinionated code formatter for PHP.
laravel/prompts v0.1.10
laravel/sail v1.24.1 Docker files for running a basic Laravel application.
laravel/sanctum v3.3.0 Laravel Sanctum provides a featherweight authentication s...
laravel/serializable-closure v1.3.1 Laravel Serializable Closure provides an easy and secure ...
laravel/tinker v2.8.2 Powerful REPL for the Laravel framework.
league/commonmark 2.4.1 Highly-extensible PHP Markdown parser which fully support...
league/config v1.2.0 Define configuration arrays with strict schemas and acces...
league/flysystem 3.17.0 File storage abstraction for PHP
league/flysystem-local 3.16.0 Local filesystem adapter for Flysystem.
league/mime-type-detection 1.13.0 Mime-type detection for Flysystem
mockery/mockery 1.6.6 Mockery is a simple yet flexible PHP mock object framework
monolog/monolog 3.4.0 Sends your logs to files, sockets, inboxes, databases and...
myclabs/deep-copy 1.11.1 Create deep copies (clones) of your objects
nesbot/carbon 2.70.0 An API extension for DateTime that supports 281 different...
nette/schema v1.2.4 📐 Nette Schema: validating data structures against a g...
nette/utils v4.0.2 🛠 Nette Utils: lightweight utilities for string & arr...
nikic/php-parser v4.17.1 A PHP parser written in PHP
nunomaduro/collision v7.10.0 Cli error handling for console/command-line PHP applicati...
nunomaduro/termwind v1.15.1 Its like Tailwind CSS, but for the console.
nyholm/psr7 1.8.0 A fast PHP7 implementation of PSR-7
phar-io/manifest 2.0.3 Component for reading phar.io manifest information from a...
phar-io/version 3.2.1 Library for handling version information and constraints
phpoption/phpoption 1.9.1 Option Type for PHP
phpunit/php-code-coverage 10.1.7 Library that provides collection, processing, and renderi...
phpunit/php-file-iterator 4.1.0 FilterIterator implementation that filters files based on...
phpunit/php-invoker 4.0.0 Invoke callables with a timeout
phpunit/php-text-template 3.0.1 Simple template engine.
phpunit/php-timer 6.0.0 Utility class for timing
phpunit/phpunit 10.4.1 The PHP Unit Testing framework.
psr/cache 3.0.0 Common interface for caching libraries
psr/clock 1.0.0 Common interface for reading the clock.
psr/container 2.0.2 Common Container Interface (PHP FIG PSR-11)
psr/event-dispatcher 1.0.0 Standard interfaces for event handling.
psr/http-client 1.0.3 Common interface for HTTP clients
psr/http-factory 1.0.2 Common interfaces for PSR-7 HTTP message factories
psr/http-message 1.1 Common interface for HTTP messages
psr/log 3.0.0 Common interface for logging libraries
psr/simple-cache 3.0.0 Common interfaces for simple caching
psy/psysh v0.11.22 An interactive shell for modern PHP.
ralouphie/getallheaders 3.0.3 A polyfill for getallheaders.
ramsey/collection 2.0.0 A PHP library for representing and manipulating collections.
ramsey/uuid 4.7.4 A PHP library for generating and working with universally...
sebastian/cli-parser 2.0.0 Library for parsing CLI options
sebastian/code-unit 2.0.0 Collection of value objects that represent the PHP code u...
sebastian/code-unit-reverse-lookup 3.0.0 Looks up which function or method a line of code belongs to
sebastian/comparator 5.0.1 Provides the functionality to compare PHP values for equa...
sebastian/complexity 3.1.0 Library for calculating the complexity of PHP code units
sebastian/diff 5.0.3 Diff implementation
sebastian/environment 6.0.1 Provides functionality to handle HHVM/PHP environments
sebastian/exporter 5.1.1 Provides the functionality to export PHP variables for vi...
sebastian/global-state 6.0.1 Snapshotting of global state
sebastian/lines-of-code 2.0.1 Library for counting the lines of code in PHP source code
sebastian/object-enumerator 5.0.0 Traverses array structures and object graphs to enumerate...
sebastian/object-reflector 3.0.0 Allows reflection of object attributes, including inherit...
sebastian/recursion-context 5.0.0 Provides functionality to recursively process PHP variables
sebastian/type 4.0.0 Collection of value objects that represent the types of t...
sebastian/version 4.0.1 Library that helps with managing the version number of Gi...
spatie/backtrace 1.5.3 A better backtrace
spatie/flare-client-php 1.4.3 Send PHP errors to Flare
spatie/ignition 1.11.2 A beautiful error page for PHP applications.
spatie/laravel-ignition 2.3.0 A beautiful error page for Laravel applications.
symfony/console v6.3.4 Eases the creation of beautiful and testable command line...
symfony/css-selector v6.3.2 Converts CSS selectors to XPath expressions
symfony/deprecation-contracts v3.3.0 A generic function and convention to trigger deprecation ...
symfony/error-handler v6.3.5 Provides tools to manage errors and ease debugging PHP code
symfony/event-dispatcher v6.3.2 Provides tools that allow your application components to ...
symfony/event-dispatcher-contracts v3.3.0 Generic abstractions related to dispatching event
symfony/finder v6.3.3 Finds files and directories via an intuitive fluent inter...
symfony/http-foundation v6.3.5 Defines an object-oriented layer for the HTTP specification
symfony/http-kernel v6.3.5 Provides a structured process for converting a Request in...
symfony/mailer v6.3.5 Helps sending emails
symfony/mime v6.3.5 Allows manipulating MIME messages
symfony/polyfill-ctype v1.28.0 Symfony polyfill for ctype functions
symfony/polyfill-intl-grapheme v1.28.0 Symfony polyfill for intl's grapheme_* functions
symfony/polyfill-intl-idn v1.28.0 Symfony polyfill for intl's idn_to_ascii and idn_to_utf8 ...
symfony/polyfill-intl-normalizer v1.28.0 Symfony polyfill for intl's Normalizer class and related ...
symfony/polyfill-mbstring v1.28.0 Symfony polyfill for the Mbstring extension
symfony/polyfill-php72 v1.28.0 Symfony polyfill backporting some PHP 7.2+ features to lo...
symfony/polyfill-php80 v1.28.0 Symfony polyfill backporting some PHP 8.0+ features to lo...
symfony/polyfill-php83 v1.28.0 Symfony polyfill backporting some PHP 8.3+ features to lo...
symfony/polyfill-uuid v1.28.0 Symfony polyfill for uuid functions
symfony/process v6.3.4 Executes commands in sub-processes
symfony/psr-http-message-bridge v2.3.1 PSR HTTP message bridge
symfony/routing v6.3.5 Maps an HTTP request to a set of configuration variables
symfony/service-contracts v3.3.0 Generic abstractions related to writing services
symfony/string v6.3.5 Provides an object-oriented API to strings and deals with...
symfony/translation v6.3.3 Provides tools to internationalize your application
symfony/translation-contracts v3.3.0 Generic abstractions related to translation
symfony/uid v6.3.0 Provides an object-oriented API to generate and represent...
symfony/var-dumper v6.3.5 Provides mechanisms for walking through any arbitrary PHP...
symfony/yaml v6.3.3 Loads and dumps YAML files
tecnickcom/tcpdf 6.6.5 TCPDF is a PHP class for generating PDF documents and bar...
theseer/tokenizer 1.2.1 A small library for converting tokenized PHP source code ...
tijsverkoyen/css-to-inline-styles 2.2.6 CssToInlineStyles is a class that enables you to convert ...
vlucas/phpdotenv v5.5.0 Loads environment variables from `.env` to `getenv()`, `$...
voku/portable-ascii 2.0.1 Portable ASCII library - performance optimized (ascii) st...
webmozart/assert 1.11.0 Assertions to validate method input/output with nice erro...
webonyx/graphql-php v15.7.0 A PHP port of GraphQL reference implementationRe: what is the difference between extension and theme?
No, these lines are still required but the lines in the "require" section must be removed if you want to delete your extensions:kuro wrote: 19 Oct 2023, 09:01 shoul i remove these lines from D:\myshop\composer.json to uninstall theme and extensions?Code: Select all
"repositories": [{ "type": "composer", "url": "https://packages.aimeos.org/aimeoscom" }, { "type": "path", "url": "packages/*" }],
"aimeos-extensions/rosen": "dev-main",
"aimeos-themes/rosentheme": "dev-main",
thank you,
but why the default files still used?
Is that also the case if you delete all entries in the madmin_cache table?
