[SOLVED ✅ ]How can i redirect on Aimeos\Base\View\Iface?
unknow76616
Post by unknow76616 » 30 Oct 2023, 14:58
I modified vendor/aimeos/ai-client-html/src/Client/Html/Checkout/Standard/Standard.php to force users to login before checkout, but I'm getting the error:
Aimeos\Client\Html\Checkout\Standard\Standard::data(): Return value must be of type Aimeos\Base\View\Iface, Illuminate\Http\RedirectResponse returned
public function data( \Aimeos\Base\View\Iface $view, array &$tags = [], string &$expire = null ) : \Aimeos\Base\View\Iface
		$context = $this->context();
		$basketCntl = \Aimeos\Controller\Frontend::create( $context, 'basket' );
		$view->standardBasket = $basketCntl->get();
		++if (!$context->user()){
		++	return Redirect::to('login');
Re: How can i redirect on Aimeos\Base\View\Iface?
Post by aimeos » 31 Oct 2023, 09:00
You will burn in (developer) hell if you modify files from the ./vendor/ directory. This is strictly forbidden!
The correct solution is to implement a Laravel middleware which checks for the route including if the user is logged in and redirects the user to the login page if not:
https://laravel.com/docs/10.x/middleware#main-content
unknow76616
Post by unknow76616 » 31 Oct 2023, 09:39
Thanks for reminding me about modifying files from the ./vendor/ directory.
I just modified the files for testing, and I will overwrite them again on extension.
I tried a regular Laravel redirect, but I'm still getting the same error:
[2023-10-31 09:31:15] local.ERROR: Aimeos\Client\Html\Checkout\Standard\Standard::data(): Return value must be of type Aimeos\Base\View\Iface, Illuminate\Http\RedirectResponse returned
code:
**    return redirect('login');**
unknow76616
Post by unknow76616 » 01 Nov 2023, 08:48
