how to upload image to product long description?
kuro
Post by kuro » 06 Nov 2023, 04:25
i can not upload image from my pc using the editor in the catalog-products-texts-
PHP/8.2.4
aimeos - 2023.10
sieg01
Re: how to upload image to product long description?
Post by sieg01 » 07 Nov 2023, 09:03
Yes, you need to have the picture on the server and just link it.
Post by aimeos » 10 Nov 2023, 08:02
Images in texts are not supported out of the box because this usually breaks the layout. You should upload the images in the media tab first and then add them in the template where they should be displayed.
