[SOLVED] Where can I find the Customer tables on DB?
unknow76616
Post by unknow76616 » 06 Nov 2023, 17:37
I'm trying to locate the specific table where shop customer information is stored. Could anyone advise on the table name dedicated to shop customers' data?
I have identified several tables related to customers (listed below), but they all seem to be empty, despite having registered customers.
| table_name |
| mshop_customer |
| mshop_customer_address |
| mshop_customer_group |
| mshop_customer_list |
| mshop_customer_list_type |
| mshop_customer_property |
| mshop_customer_property_type |
$cntl = \Aimeos\Controller\Frontend::create( $context, 'customer' );
These tables should contain information about customers who signed up using the shop site ?
Re: Where can I find the Customer tables on DB?
Post by aimeos » 10 Nov 2023, 07:56
If you are using Laravel, the customer records are stored in the users* tables.
unknow76616
Post by unknow76616 » 12 Nov 2023, 08:30
What does 'customer.id' refer to?
after i insert new user :
$context->db()->insert(
            'users',
                'firstname' => $firstname,
                'lastname' => $lastname,
                'name' => $name,
                'mobile' => $mobile,
                'password' => Hash::make($password),
                'siteid' => $siteid,
                'mobile_verified_at' => date('Y-m-d H:i:s')
then try visit {{site}}/profile got this error
[2023-11-12 11:25:52] local.ERROR: Item with ID "16" in "customer.id" not found {"userId":16,"exception":"[object] (Aimeos\\MShop\\Exception(code: 404): Item with ID \"16\" in \"customer.id\" not found at ./vendor/aimeos/aimeos-core/src/MShop/Common/Manager/DB.php:631)
Post by aimeos » 14 Nov 2023, 08:00
Most likely your siteid value doesn't match. The site ID (e.g. "1.") must be the one of the site code (e.g. "default") which you use in your URL (because of "{site}/..."). If you want customers to be available in all sites, you can also use an empty string as site ID value.
unknow76616
Post by unknow76616 » 14 Nov 2023, 08:45
Thanks @aimeos, your latest answer inspired me to understand where the problem is. Now I know that the format of the site ID is:
siteid => $siteid."."
