How do we turn off the related products feature in basket page
unnimaya-seeroo
Post by unnimaya-seeroo » 13 Nov 2023, 12:56
Environment
Laravel : 10
Aimeos : 2023.04
Would it be possible to turn off related products in the basket page (Products you might be also interested in)?
What is the criteria for that list?
Is it possible to manage that from the admin side?
Re: How do we turn off the related products feature in basket page
Post by aimeos » 14 Nov 2023, 07:44
To disable the related products in the basket, just remove the "basket/related" from the config:
https://github.com/aimeos/aimeos/blob/m ... op.php#L56
unnimaya-seeroo
Post by unnimaya-seeroo » 14 Nov 2023, 08:14
Thanks Aimeos,
Could you please explain the criteria of products appeared there.we found scenario like, the purchased products within a period of time and also can able to customise the number of products displayed there (default 6), But not able understand the confident value and its calculation. What is included in confident value calculation? Please advice.
