[Solved] Challenges with Overriding Aimeos Product Controller
unknow76616
Post by unknow76616 » 17 Nov 2023, 12:25
How can I override vendor :
vendor/aimeos/ai-admin-jqadm/src/Admin/JQAdm/Product/Standard.php
I tried to override it by creating :
./packages/myext/src/Admin/JQAdm/Product/Standard.php
, but it didn't work out
I follow up https://aimeos.org/docs/2023.x/admin/jq ... hop%20site.
Also clean up cache
Php8.1 , Ubuntu
Re: Challenges with Overriding Aimeos Product Controller
Post by aimeos » 20 Nov 2023, 17:02
You can't create a new class with the same name because composer will choose the first one (whichever that is). Instead, you have to give your class a new name (e.g. "Myproject") and configure your new class name to be used by the factory, i.e.:
admin/jqadm/product/name = Myproject
See here how to use the configuration:
https://aimeos.org/docs/latest/laravel/customize/
unknow76616
Post by unknow76616 » 20 Nov 2023, 21:06
