Cms forms issue
KhushalWebroot
Cms forms issue
Post by KhushalWebroot » 29 Nov 2023, 10:57
We are experiencing an issue with our CMS forms. We are receiving only the message field value in our e-mails after a user submits a form. Please advise.
Also how to add recaptcha?
Re: Cms forms issue
Post by aimeos » 30 Nov 2023, 07:30
There has been a change in 2023.10.x-dev which fixes the issue. Please update using:
composer req aimeos/ai-cms-grapesjs:2023.10.x-dev
If you want to add reCaptcha, you need to extend the GrapesJS block for the contact form in the ./themes/admin/jqadm/custom.js file of your project-specific Aimeos extension in the ./packages/ folder.
