mPAY24 Payment provider?
andreas.allacher
Post by andreas.allacher » 22 Feb 2016, 17:28
I would like to know if there is already a payment provider for mPAY24 or if someone is working on one for aimeos?
Re: mPAY24 Payment provider?
Post by aimeos » 23 Feb 2016, 15:39
Someone implemented this for a very old version which isn't working any more:
https://github.com/Arcavias/ext-payment ... ll/1/files
Maybe you can use it as inspiration for creating an Omnipay driver.
andreas.allacher
Post by andreas.allacher » 23 Feb 2016, 17:44
Thanks.
I guess I will create one using that plugin.
After I have created everything else :)
Just one question: Do you think it is better/easier to create an OmniPay driver or directly one for aimeos (after all the payment is for arcavias)
Post by aimeos » 23 Feb 2016, 18:32
Omnipay drivers can be used for other projects as well and the chance that others will contribute is much higher than for an Aimeos payment service provider. Most of the time Omnipay drivers are "good enough" and there's no need for the advanced possibilities Aimeos is offering.
