New subpart for catalog filter
Gagik
Post by Gagik » 06 Dec 2023, 13:48
PHP version: 8.1
Laravel version: 10
Aimeos version: 2023.07
Environment: Linux
I want to add new sub part for Catalog Filter. In the source code for Catalog filter
I found 5 sub parts: Tree, Search, Price, Supplier, Attribute. I want to add new sub part like for example Supplier sub part
Where must I create new controller and layout for new sub part?
Re: New subpart for catalog filter
Post by aimeos » 08 Dec 2023, 09:09
Please note that 2023.07 isn't supported any more and you must update to 2023.10 LTS.
Add a new class and an appropriate template in your own extension using the same directory and naming structure. Afterwards, configure your new sub-part to be used by:
https://aimeos.org/docs/2023.x/config/c ... /#subparts
