Aimeos extension builder
cnoelker
Post by cnoelker » 23 Feb 2016, 14:00
the link on this page
https://aimeos.org/docs/Developers/Create_an_extension
to the Aimeos extension builder located at
http://aimeos.org/developer/extensions/
is not available and redirects to the home page.
What is the correct link?
Claudia
Re: Aimeos extension builder
Post by aimeos » 23 Feb 2016, 15:57
The link is https://aimeos.org/developer/extensions/ (with https://) but you should get redirected nevertheless. The link in the documentation has been changed.
Thank you for the hint!
cnoelker
Post by cnoelker » 23 Feb 2016, 16:20
Thank you for the link. However, using this yields an error:
Invalid project name
Only a-z, 0-9 and underscore ("_", not at the beginning or end) characters are allowed in project names
My project name: xxxx
TYPO3 Extension
The error occurs no matter which extension type I choose.
Claudia
Post by aimeos » 23 Feb 2016, 16:28
Hi Claudia
Sorry, I've uploaded a new version of the extension builder a few minutes before I wrote you. But the name check was wrong for TYPO3 extensions ("must" instead of "may" contain an underscore).
Tom
cnoelker
Post by cnoelker » 23 Feb 2016, 16:51
Thanks, now it works! :-)
