Basket storage
Gagik
Basket storage
Post by Gagik » 21 Dec 2023, 16:04
PHP version: 8.1
Laravel version: 10
Aimeos version: 2023.10
Environment: Linux
Where is stored the basket in this version of Aimeos ? Session or database table ?
Re: Basket storage
Post by aimeos » 22 Dec 2023, 09:35
In the mshop_order_basket table.
hyalcin
Re: Basket storage
Post by hyalcin » 09 Aug 2024, 13:51
How can we manage the process without using basket? After selecting the products from the page where the products are listed, it will be directed to the address page and then the summary will be converted to pdf
Re: Basket storage
Post by aimeos » 13 Aug 2024, 04:44
The basket page is required because it's the only way to add products for the checkout if you don't use the JSON:API
hyalcin
Re: Basket storage
Post by hyalcin » 14 Aug 2024, 09:39
Thanks for your answer. I can use it on the backend side, but I don't want to be directed to the basket on the frontend side.
