Disable checkout address billing
Gagik
Post by Gagik » 29 Dec 2023, 12:32
PHP version: 8.1
Laravel version: 10
Aimeos version: 2023.10
Environment: Linux
I want to disable checkout address billing from my project. Will I change something in 'config/shop.php' file or another way ?
Re: Disable checkout address billing
Post by aimeos » 30 Dec 2023, 17:55
Usually, you need at least one address and if that's also true for you, keep the billing address and disable the delivery address instead. You can use this configuration in your ./config/shop.php to disable the relevant subpart(s):
https://aimeos.org/docs/2023.x/config/c ... /#subparts
