Make products available based on region (depend on cites)
tekgroup
Post by tekgroup » 17 Jan 2024, 16:09
I need to make my site depend on customer region ,
First of all customer will choose his region then I will show all products available in his region !
How can I implement that at aimeos?
tekgroup
Re: Make products available based on region (depend on cites)
Post by tekgroup » 23 Jan 2024, 14:12
Is that any way to make aimoes multi stock?
Post by aimeos » 23 Jan 2024, 14:17
tekgroup wrote: 23 Jan 2024, 14:12 Is that any way to make aimoes multi stock?
Yes, Aimeos can store several stock levels per product. In the admin backend, go to Types > Stock and add your warehouses. Then, you can add one stock level per warehouse in each product.
Post by aimeos » 23 Jan 2024, 14:21
tekgroup wrote: 17 Jan 2024, 16:09 I need to make my site depend on customer region ,
How many regions do you have?
The Aimeos company offers thier ai-sites extension which you can not only use for marketplaces but also for products tied to sub-sites (and sub-sub-sites) which then can be chosen by the customer in the frontend (B2B setup):
https://aimeos.com/extensions#c436
