Aimeos typo3 extension not working properly
Tboi
Post by Tboi » 22 Jan 2024, 11:44
I've installed aimeos typo3 extension but some options/buttons are not working in the backend. What could be the problem
Linux
PHP 8.2
Typo3 12.4
MySQL 8.0.35
Re: Aimeos typo3 extension not working properly
Post by aimeos » 22 Jan 2024, 11:47
Please open the browser console to see if there are JS errors.
Tboi
Post by Tboi » 22 Jan 2024, 14:27
Worked it out, it's now running perfectly fine. Now how do I customize the theme and templates to my specific needs if I'm using the typo3 extension, not the laravel package?
Post by aimeos » 23 Jan 2024, 11:28
Please have a look at these articles:
https://aimeos.org/docs/latest/typo3/#html-frontend
If you want to customize the theme, you can either add a common CSS file you add to each page if it's not much you want to change. Otherwise, you can copy the existing CSS/JS files from the existing theme to a new directory (e.g. in ./fileadmin/aimeos/) and change the fs-theme filesystem configuration in your own project specific Aimeos TYPO3 extension:
https://github.com/aimeos/aimeos-typo3/ ... hp#L58-L63
