Single basket per user
Gagik
Post by Gagik » 31 Jan 2024, 06:15
PHP version: 8.1
Laravel version: 10
Aimeos version: 2023.10
Environment: Linux
I have seen that user can have many baskets in the database. I mean that in the database exists user baskets archive. I want to prevent that and change the functionality to 'single basket per user'. What is the entry point/file for that ?
Re: Single basket per user
Post by aimeos » 05 Feb 2024, 11:01
You have to overwrite this class:
https://github.com/aimeos/aimeos-core/b ... andard.php
Up to 2023.10, the relevant getSession()/setSession() methods you need to overwrite are in the Base.php:
https://github.com/aimeos/aimeos-core/b ... p#L60-L147
In 2024.01+, the methods have been moved to a trait but can be overwritten the same way:
https://github.com/aimeos/aimeos-core/b ... ession.php
Gagik
Post by Gagik » 06 Feb 2024, 06:16
Thank you.
