create new component
malik_kat
Post by malik_kat » 31 Jan 2024, 07:49
I worked to build a new component .
The component functionality
Is showing some of category in all page in website with own design.
I created a class in myshop\packages\myextension\src\Client\Html\Catalog\Mycomponent\Standard.
I created a template in myshop\packages\myextension\templates\client\html\catalog\mycomponent\mycomponent-body.php.
In mycomponent-body.php file build a html structure .
My problem is can't get any change on frontend.
Can you please provide some hint to do this?
Gagik
Re: create new component
Post by Gagik » 31 Jan 2024, 12:15
Hi
If you want to show this component in all pages of your project, you can solve this by writing logic in your project framework files (Laravel, Symfony) using 'Aimeos' ORM structure inside file.
Post by aimeos » 05 Feb 2024, 11:06
Guess, you are using Laravel, don't you?
To add a new component in Laravel, add it to the entries in the "pages" section of your ./config/shop.php file where you want them to appear (name is "catalog/mycomponent" in your case). Then, adapt the Blade templates of that pages and add the output of "aibody" and "aiheader" like in this template:
https://github.com/aimeos/aimeos-larave ... .blade.php
malik_kat
Post by malik_kat » 06 Feb 2024, 14:42
Thanks for this replies @aimeos @Gagik
I have try as per your instructions and it worked.
