Issue with Middleware Redirect to Login Page - JS script code/file Not Loading
unknow76616
Post by unknow76616 » 03 Feb 2024, 11:01
Hello Aimeos community,
I hope you're all doing well. I am currently facing an issue with a Laravel middleware that redirects users to the login page if they are not authenticated. The redirection works as expected, but I've noticed that the JS script Code/files are not loading on the login.blade.php page.
Here is the relevant code from the middleware:
protected function redirectTo($request)
    if (! $request->expectsJson()) {
        return airoute('login');
https://github.com/aimeos/aimeos/blob/1 ... te.php#L18
Re: Issue with Middleware Redirect to Login Page - JS script code/file Not Loading
Post by aimeos » 05 Feb 2024, 11:15
What JS code isn't loaded? Is there a 404 in the browser console for the JS file?
