Modify add to basket behavior
malik_kat
Post by malik_kat » 06 Feb 2024, 14:52
PHP Version 8.2.12
Laravel version: 10
Aimeos version: 2023.10
Environment: windows (XAMPP cross-platform web server).
How i can change a behavior to procedure add product to basket .
I want when user click on button "add to basket".
The product will be add to basket without show checkout popup
Gagik
Re: Modify add to basket behavior
Post by Gagik » 07 Feb 2024, 06:17
Hi
Default implementation:
https://github.com/aimeos/ai-controller ... d.php#L330
You should overwrite this class.
Post by aimeos » 07 Feb 2024, 07:35
malik_kat wrote: 06 Feb 2024, 14:52 How i can change a behavior to procedure add product to basket .
If you only want to avoid the popup and pass the customer directly to the basket, overwrite this JS method and simply return "true":
https://github.com/aimeos/ai-client-htm ... #L362-L378
malik_kat
Post by malik_kat » 07 Feb 2024, 10:14
I dont need pass the customer directly to the basket when click on button add to basket .
I need him to continue shopping and when he finished the shopping press on basket button to checkout and payment.
Post by aimeos » 08 Feb 2024, 10:22
Then just remove the createOverlay() and createContainer() from the mentioned onAddBasket() method
malik_kat
Post by malik_kat » 08 Feb 2024, 14:02
Thanks for this replies @aimeos
It worked.
