how to authenticate with react and do shop configuration???
ridoywsit
Post by ridoywsit » 09 Feb 2024, 02:32
Hi team,
PHP version: 8.1
Laravel version: 10
Aimeos version: 2023.10
Environment: Linux
I am working on with aimeos project. My frontend in React. I am using the Aimeos JSONAPi. In few areas I am confused.
1. How to authenticate the user and process checkout when user is logged in?? In frontend I am using react. I wrote a login api seems it doesn't serve purpose. Not sure what I am missing.
2. Is it possible to implement social login with facebook and google??
3. Also I am trying to get products from nested category when visiting parent category. Same as category when I clicking on a single category i would like to get all nested category list in one single query. In documentation i see the configuration guideline. But not sure how to write in config/shop.php file. Here is the documentation: https://aimeos.org/docs/2021.x/config/c ... ct/#levels
Re: how to authenticate with react and do shop configuration???
Post by aimeos » 12 Feb 2024, 07:29
ridoywsit wrote: 09 Feb 2024, 02:32 1. How to authenticate the user and process checkout when user is logged in?? In frontend I am using react. I wrote a login api seems it doesn't serve purpose. Not sure what I am missing.
The best option is to use JSON Web Tokens (JWT) for authentication. The Aimeos headless distribution has already included it for login:
https://github.com/aimeos/aimeos-headle ... n-rest-api
ridoywsit wrote: 09 Feb 2024, 02:32 2. Is it possible to implement social login with facebook and google??
Laravel offers Socialite, a package for social login:
https://laravel.com/docs/10.x/socialite
You have to check how this works with JWT.
ridoywsit wrote: 09 Feb 2024, 02:32 3. Also I am trying to get products from nested category when visiting parent category. Same as category when I clicking on a single category i would like to get all nested category list in one single query. In documentation i see the configuration guideline. But not sure how to write in config/shop.php file. Here is the documentation: https://aimeos.org/docs/2021.x/config/c ... ct/#levels
Here it's documented how you have to add the configuration to PHP files like in Laravel's ./config/shop.php:
https://aimeos.org/docs/latest/laravel/ ... figuration
